Pics of the Nightshade 15
Why don't you look on Sundown's site. I think the Z is a heavier-duty woofer than the Nightshade.
Night shade is more heavy duty buck.......z 2 stacked motor nightshade 3 stacked...also will take a ton of power...this 1500 rms is bs...more like 2500
Z v.1 -- 1000 RMS / Similar to TC-9 type motor / 4-layer round aluminum coil
Z v.2 -- 1500 RMS / Heavy double stack (similar weight to NS v.1) / Internal Shorting Ring / 4-layer flat aluminum or 4-layer bifilar round copper coil
NS v.1 -- 1500 RMS / Triple Stack / 8-layer flat aluminum coil (several WW versions; 42mm OG / 50mm most newer ones)
NS v.2 -- 2000 RMS / Triple Stack (slightly shorter magnet stack) / very thick back and top plates / dual shorting rings / better cooling / 8-layer flat aluminum coil @ 71mm long stock
gracias
Hey jacob I emailed u 3 weeks ago....no reply
Ok bout these recones.... Why shouldn't he just get a sundown recone as vs to one by splaudio or some1 else..??
Wouldn't there parts make it sound different..?? Just curious and asking! :)
I'd suggest re-sending as my auto-reply suggests:
"Due to the high e-mail volume we receive at Sundown Audio it may take some time to respond to your inquiry. If you do not receive a reply within 2 or 3 days it is advisable to re-send your e-mail to make sure we received it. Thanks for your patience."
If it takes more than a few days or so; may be lost in cyberspace.
Alternatively you can e-mail Brandon at contact@sundownaudio.com or brandon@sundownaudio.com
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains...
5
Imtjnotu
Me Gusta Edition
Imtjnotu
San Diego CA
sacsking916
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
