Pioneer Head Unit - USB Sound quits for 1-2 seconds when I hit a bump
  • 1
Jonny Steward
CarAudio.com Newbie
Hi,
I have been searching high and low for what might be causing this, or if it is a "feature" of the head unit itself.
I will be driving along, listening to music via USB drive, when I hit a bump the sound stops for 1-2 seconds, then comes back on. Checked the wiring, that all looks fine. Occasionally I will hit a bigger bump and it will give a format read error. Unplugging the USB and putting it back, picks up the song where it left off.
I drive a Honda Civic Si and feel pretty much every bump in the road, so it gets pretty annoying. Any thoughts on how to fix it? Or recommendations for a replacement?
Head unit is Pioneer DEH-S4120BT
This looks like they went in and rewired some wires. 12 volts or a little less than 12 volts. When not enough volts are going through it, your...
6
You need to re-phrase the question. Are you trying to use active bi-amplification via outboard amplifiers or do you just want the recommended...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
487
Jonny Steward
CarAudio.com Newbie
Jonny Steward
Tampa, FL
Jonny Steward
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
