SOLD Pioneer Premier Amps + Eclipse SW9122 + Hertz 8"'s + Hertz HT28 Tweets, Diamond 7.1
  • 4
newtitan
CALI
1) Diamond Audio D5 7.1 (5.1 plus two stereo sub channels, that can be bridged also)
I bought this to use to power my surround system, but I dont plan to use my ms8 till I get my suburban in a few months
so thought maybe someone could use it
225 shipped
http://img.photobucket.com/albums/v693/newtitan/IMG_1548.jpg
here are some specs from the manual
Quote:
SPECIFICATIONS
Frequency Response: 10 – 50,000 Hz
Signal-to-Noise Ratio: 100dB
THD Front, Rear, and Center: 0.03%
THD sub Channels: 0.05%
Channel Separation: 80dB (min.)
Input Sensitivity: .2 to 5V RMS
Input Impedance: >20k Ohms
Power Supply Operating Range: 11 to 14.5V DC
1 Diamond Audio Technology
DIMENSIONS
D5 5.1
Length: 17"
Width: 12"
Height: 2 3/4"
CONTINUOUS RMS OUTPUT POWER
Note: Full Rated Power is generated at all voltages between 11 and 14.5VDC.
D5 5.1
60W x 5 @ 4 Ohm (min. impedance)
and
70W x 2 @ 4 Ohm
or
140 x 2 @ 2 Ohm (min. impedance)
or
280 x 1 @ 4 Ohm Bridged (min. impedance)
CROSSOVER SPECIFICATIONS
Quantity: 5 - Fully Independent
Type: 3 Defeatable Fixed Highpass (front, rear, and center)
1 Adjustable Lowpass (sub channels)
1 Adjustable Sub-sonic (sub channels)
Slope: 12 dB/oct.
Alignment: Butterworth
2) Pioneer GM-X1022 CLASS A (I have two of these, the older purple ones) 125 shipped each, or 225 shipped for the pair
100x2, 300x1 bridged
http://img.photobucket.com/albums/v693/newtitan/IMG_1416-1.jpg
3) Pair of Hertz HT28 tweeters MINT,
these have about 10hrs on them, I dont have the mounting cups, bought retail, so they have a warranty (youd have to send them back to me though)....pretty hard to find by themselves, since most people get the HT20/25, these play lower and have a cleaner top end, need far less eq imo
4) Hertz HV 200 8" midbass/midrange
they are used, albeit mint, I have the original box, I run them up to70hz @ 18db through 500hz @24db @ 200 watts, and they are awesome
Im trading in my truck so I stocking everything back up till I can get my suburban
$200 shipped
5) Eclipse SW9122
This is a 12", its sealed, has the manual of course...ive stocked this for a long time..but things change so its up for sale
$300 shipped
6) Pair of Hertz HT28 tweeters MINT,
these have about 1 month on them, I dont have the mounting cups, bought retail, so they have a warranty (youd have to send them back to me though)....pretty hard to find by themselves, since most people get the HT20/25, these play lower and have a cleaner top end, need far less eq imo
http://www.hertzaudiovideo.com/Doc/H...nergy_HT28.pdf
pics will posted in a few, they are MINT
these will play down close to 2K @ 24db if need be
$150 shipped
How smooth would you say those tweeters are? I have a set of cdt's and my gosh they are harsh.
they are significantly better, more linear, smoother, play lower than all the cdt tweeters ive used, ive used most of them
love to sell some of this stuff, I want a cheap local DLP
trades work too
I could use some nice headphones!!!
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
479
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
908
newtitan
newtitan
CALI
newtitan
    Jun 3, 2024
