Pioneer Premier PRS-X720
  • 2
bigguy2010
SQ
736
MI
Used, but in great shape with end cap and ALL screws.
$150 shipped
Continuous Power (20Hz-20kHz, 0.04% THD)
2 ch: (4 Ohm) 100Wx2
2 ch: (2 Ohm) 200Wx2
1 ch: (4 Ohm) 400Wx1
Maximum Power (EIAJ)
2 ch: (4 Ohm) 250Wx2
1 ch: (4 Ohm) 750Wx1
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion:
Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features
Bridgeable 1/2/3 Channel Capability
PWM Regulated MOSFET Power Supply
2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
Balanced Isolator Input Circuit
Oversized Gold-Plated Screw-Type Power/Ground Terminals
Gold-Plated Screw-Type Speaker Terminals
Gold-Plated RCA Inputs
Gold-Plated RCA Outputs (Full Range)
Hi-Volt Input Level Control (400mV-6.5V)
Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
Variable Bass Boost (40-120Hz, 0 to +18dB)
Subsonic Filter (15Hz, -18dB/Oct.)
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
457
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
882
bigguy2010
SQ
bigguy2010
MI
bigguy2010
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
