Pioneer ts w261d4 box help
  • 2
Kwtruck
This is my first post here thanks for the help in advance . I tried the search button but kept telling me lost connnection to local host. This is the first system I've done in about 10 years to say things have change would be a understatement .
I need help with box size and port length for pioneer sub I built the typical down fire box frame 2002 chevy Silverado extended cabi glassed the bottom and plan to put a divider in using 1 side as a sub enclosure and the other side under seat storage pioneer says .8 sealed or 1.1 ported with a 3 inch port 7 inches long problem is I can't find a box program to work on a iPad any help would be appreciated
I forgot to mention I'm powering it with a old alpine monoblock giving it 400 watts and mainly listen to rock and a bit of country. No rap for me front stage I'm ordering nvx 6.5 components with about 75 watts a channel
This is my first post here thanks for the help in advance . I tried the search button but kept telling me lost connnection to local host. This is the first system I've done in about 10 years to say things have change would be a understatement .I need help with box size and port length for pioneer sub I built the typical down fire box frame 2002 chevy Silverado extended cabi glassed the bottom and plan to put a divider in using 1 side as a sub enclosure and the other side under seat storage pioneer says .8 sealed or 1.1 ported with a 3 inch port 7 inches long problem is I can't find a box program to work on a iPad any help would be appreciated
Get the xplicit audio app, pretty accurate compared to Torres desktop calc.
Sent from my SCH-I605 using Tapatalk
Thanks for the help I downloaded the app and going with what pioneer recommends it will be tuned to almost 46 that's just not work for me . I'll play around with it some and see what I can come up with
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
520
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
940
Kwtruck
Kwtruck
Georgia
Kwtruck
