pioneer vs. premier?
  • 5
QUOTE=thevic24;7493088]Did you replace the pico or just re ground the jacks?
Iam replacing my Pioneer HU but would like to fix it and give it to the old man.(Pops).
I just grounded the pico. But booms method is a more permanent method. Both fix the issue nonetheless.
Well is it worth my time and money, or should I look into a kenwood excelon, or eclipse?
Yes it’s worth fixing. Just ground the rca's I am sure you have a 1 ft piece of wire somewhere in your house. If not it will cost you like $1 to get some. If you still dont wanna fix it I will give you a few bucks for it.
If your asking if buying a Pioneer is a good idea then yes it is. Just don't hot swap the rca's and you want have a issue with the pico..
IMO yes, fix it.
I wrapped a small wire around the RCA's and all was good. I will take the above advice and drop a bead of
solder on it and just be done with it.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
350
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
770
flatland
flatland
Louisville KY
nateberrier
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
