Planet Audio BB2400.1
andrewtexas123
3/4 mounting feet are broken off
No bass knob
Works 100% this right here is cheap power that sounds good!
Big Bang Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 1000 watts x 1 chan.
2 ohms: 1600 watts x 1 chan.
1 ohm: 2400 watts x 1 chan.
MAX Power Rating:
1 ohm: 3000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +18 dB bass boost)
Soft Start Turn-on
Mono channel operation
Strap two amps together for twice the power
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated rca level inputs
Chrome-plated set-screw terminals
Input sensitivity:
Low level: 100mV-2V
High level: 2V-8V
Variable low-pass filter
Subsonic filter (15-40 Hz)
Phase Shift: 0-180º
Frequency response: 20-250 Hz
Dimensions: 21-3/4"L x 6-7/8"W x 2"H
$200 shipped
cheaper amps dont get low and if they do sure dont sound good low my power bass got down and sounded great should have kept that baby this is not a post dump at all i am interested in getting somethin that sounds good my power acoustik couldnt get down and my lil visonik i had for my 6x9s that im usin right now for a lil bump couldnt hit low to save its life AMPS DO HAVE FREQ RESPONCE IN SPECS just sayin
Im not a power acoustik fan but you should have tried the bamf's they get down for what they are regardless to what anyone says about them. Just like with the amp i have now some ppls say its power acoustik but the clamp numbers say other wise
Very nice mp here! A lot of power for the money! Does about 2200 wts rms at 1 ohm (which is not rated) just to clarify. Steal of a deal for $200.
V.
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
A Link would be very helpful. Id be interested in taking a look at some gear
248
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
andrewtexas123
andrewtexas123
Danville, Ca
andrewtexas123
