Croby95
Hello!
I am having a lot of trouble getting my subs to work in my 2003 Acura RSX Type S. I have 2 12" DVC Hifonics subs (400w RMS each) hooked up at 1 ohm to a Hifonics BRX1000.1D amp(1000w RMS @1ohm). All the connections are SOLID but amp nor subs will seem to work. I spliced the wiring harness for my single din stereo (JVS KD-R330) properly.
The other day the amp would turn on when the remote wire was connected to the blue/white amp turn-on and brown amp trigger wire but the subs wouldn't play, however now the amp won't even turn on. I tried connecting the remote wire to the yellow/red switched 12v+ wire and the amp didnt turn on then either. The radio turned on though when it was connected to either. With both connections (blue/white AND yellow/red), the power light on the amp would blink.
I even tried it all out with my old amp (Hifonics HFi1000.1D) and a brand new head unit and couldn't get anything to work. Tried a different remote wire too, no luck. All fuses are intact! I read something about bypassing the stock Bose amp under the passenger seat? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Need to fix the remote wire problem first so the amp will at least turn on... Took it to best buy for a quick diagnosis and the remote wire only has 3v, the other amp terminals tested normally.
Any help is appreciated! Hope to have it fixed by Monday so i can bump on the way up to NY to watch USA vs. Ghana with my college friends! //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
