Please Help Dont wanna Blow my System up...
  • 5
pcortez86
I just bought 2 new sets of speakers and one 4 channel amp. how do i hook these up. I have infinity kappas 6.5s(2ohm) in front and Boston Acoustic 746(4ohm) in the back and a Alpine MRp F240 4 channel amp. Will i damage my speakers or amp by hooking up a set of 2ohm speakers and a set of 4ohm spears to my 4channel amp. If not how do i hook these up to my amp? any info would be greatly appreciated.
Running different impedances will not blow up the amp or speakers, assuming the 2ohm load goes on the front or rear channel, while the 4ohm load goes to the other 2 channels.
thanks for your help. So i am going to hook up the infinity kappas(2ohm) to channel 1 and 2 and the BA's (4ohm) to channels 3 and 4. This should be fine correct.
---------- Post added at 04:10 PM ---------- Previous post was at 04:09 PM ----------
thanks
thanks
Correct.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
pcortez86
pcortez86
Bay Area, CA
sacsking916
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
