Please Help! Interfearance in sound!
  • 2
TheDem6n
I have just installed my set of component in a new car, i connected the speaker cable from the amp to exsisting wiring behind the headunit as its a very big problem to get the wiring into the doors in these cars (was told by a car audio installer that the exsisting wiring is good enough for the power i will be running through it) but now i'm getting the interfearence in the speakers! The power cable is run down the other side of the car so thats not it! In my other ca which was the same make i had no problems with this method and i still got same equipment!
So what can i do?????//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif its driving me mad!
What kind of noise is it? Does it increase in volume if you change the HU volume? Is it a whining? Or is it a clicking? If so, does it speed up with engine RPM? Is it just static? What equipment are you running? What kind of car do you have? What's the last thing you ate?
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
TheDem6n
TheDem6n
Cambridge, Uk
XanderMoser
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
