Please help me fix my enclosure
  • 3
So i built a 6.25 cu ft box tuned to high 20's and the port resonates on the inside of the box. This caint be heard from in the car but outside it can be. How can i strengthen the port and box to eliminate this without adding more screws? Would fiberglassing the inside not including the port area work? Im also looking to decrease my box volume just a smudge. Maybe half of 1 t^3
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
969
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Jkidd288
Jkidd288
Greensboro, NC
Jkidd288
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
