PLEASE help me
  • 2
88joey
NY
Hey guys I'm new like fresh new.. I seen a JBL 75EZ amp @4 ohm and 750 @2ohm .. Now I want to buy 2 4ohm dvc subs in box but for 100 I get box with subs , Now will 500 be enough ? Cause I heard u can not wire Two DVC 12's 4 ohm subs together to get a 2 ohm so I'm stuck with the 500 at 4 ohms on jbl amp... Amp is CEA tested and good deal. The subs say 300 roms each, could they be lieing ? they are hifonics 12's in a box and are Zeus hifonics on eBay... I only have$200 to spend on amp and box... I want better amp and can buy better speakers next month anyway ... So would 500 @ 4ohm on amp be ok for 2 12 subs at 300 each ? I can't see cheap subs going at rms 300 each 12 though ??
Please any help here... Should I buy a 1 ohm amp ? I read the jbl one is really good and tested its just I can't get at 2 ohms on it with dvc subs so I'm lost.....
I am new to this also but learned allot so far and everyday I keep holding off as a new thing pops up and I am loosing my mind.
PLEASE HELP ME ..... eBay Hifonics Zeus 12's in box ( 4ohm each and dvc ) $106..... JBL amp 75ez 750@2ohm and 500 @4ohm.... Will this work , Eventually I will get 2 12's that are SVC so I can get to a 2ohm on amp..
Thank You , I'm not rich at all and need it for now and will get better subs later on for now I need good amp as its better to have better amp and worse speakers then vice verse ?
You can get to 2 ohm with 2 dvc 2ohm subs if your dedicated to that amp try finding a dual woofer package with 2ohm dvc subs
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
956
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
88joey
88joey
NY
els1989
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
