Please help...new to this bumpin stuff....
  • 2
Tryin2bump
Michigan
I just got a RF Punch X150.1 and a RFP 3412 HE sub.....I have a 2001 2 door Blazer and would like to make my own Box for the 12 but have no idea in what direction to go....as far as sealed/ported/bandpass...etc.....anybody have any ideas as to what a good box would be...? Thanx in advance...
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
957
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Tryin2bump
Tryin2bump
Michigan
Tryin2bump
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
