please help this rookie with headrest dvd monitors
  • 2
latex55
hey guys need some help. have a 2013 pathfinder and i ordered dual dvd headrest monitors online.
i tried to install them last night and i cant figure out once i run the cable down the seat rest bar and down the back of the seat, where does that power cable plug into>
reviews online said how easy install was. i have the fuse box and all of that but my question is do i have to run power to the back of the seat or is there already one end of a power switch underneath the seat? thanks
I usually run the ground wire to the kickpanel and ground there and you have to run to power wire I usually tag the radio power with a relay to turn them on and off with the ignition or just tag the ignition wire.
Where are you getting video source from? Just tag that power wire
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
latex55
latex55
Dallas, TX
winkychevelle
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
