Polk PA330 2 channel
  • 3
Ge_off_me
Parts Express Specialist
7,013
Enon, Ohio
Total Frequency Response 10Hz-30kHz
Signal-to-noise (Referenced to rated power) 80 dBA
Remote Gain no
Minimum Impedance Bridged 4 ohms
Minimum Impedance Not Bridged 2 ohms
Protection Circuitry 25 Amp ATC fuse, reverse polarity, thermal and DC offset
High Pass Filter
Filter Slope 12dB/oct
Low Pass Filter
Effective Damping Factor >100
CEA2006 Rating 200 watts / 4 ohms
Input Impedance 15 k ohms
Max Sensitivity 175mV - 8 dB
Dimensions
Product Weight (each) 4.70 pounds
With Panels
Height 1 15/16" (4.92cm)
Width 7 3/4" (19.68cm)
Depth 8 1/8" (20.64cm)
Amplifier Specs
Channels 2
Channel Notes Bridgeable Class AB MOSFET
Total Dynamic Power 300 watts
Bass Boost Characteristics 3-position(0,6,12dB) Hz
12V & Ground Cable Gauge 4AWG
Shipping
Total Shipping Weight 6.70 pounds
Amplifier Power Specs
RMS Power at 14.4V
Watts per channel NOT bridged @ 1 kHz
4 ohms 75 watts
2 ohms 100 watts
Watts per channel bridged
4 ohms 200 watts
Pretty darn good condition, probably a 8.5-9/10
I used this amp and the matching PA660 that is also listed for sale in my MECA SQ car and got 4th in my class at World Finals.
40+shipping
You pay.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
432
6
502
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
881
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
497
Ge_off_me
Ge_off_me
Enon, Ohio
LBC99
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
