Polk PA660 4 channel
  • 2
Ge_off_me
Parts Express Specialist
7,013
Enon, Ohio
Total Frequency Response 10Hz-30kHz
Signal-to-noise (Referenced to rated power) 75 dBA
Distortion at Rated Power 0.9 %
Minimum Impedance Bridged 4 ohms
Minimum Impedance Not Bridged 2 ohms
High Pass Filter
Filter Slope 12dB/oct
Low Pass Filter
Effective Damping Factor >100
Max Sensitivity 250mV-5V (rear) dB
Dimensions
Product Weight (each) 7.60 pounds
With Panels
Height 2" (5.08cm)
Width 13 1/4" (33.66cm)
Depth 8 1/8" (20.64cm)
Amplifier Specs
Channels 4
Channel Notes Bridgeable Class AB MOSFET
Total Dynamic Power 600 watts
Bass Boost Characteristics Variable (0dB to +8dB) Hz
12V & Ground Cable Gauge 4 AWG
Shipping
Total Shipping Weight 9.60 pounds
Amplifier Power Specs
RMS Power at 14.4V
Watts per channel NOT bridged @ 1 kHz
4 ohms 75 watts
2 ohms 85 watts
Watts per channel bridged
4 ohms 200 watts
I used this amp and the matching 2 channel also being listed for sale in my MECA SQ car last year and got 4th in my class at World Finals.
Pretty good condition, about a 8.5/10
comes with original box
80+shipping
You pay.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
432
6
502
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
881
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
497
Ge_off_me
Ge_off_me
Enon, Ohio
Ge_off_me
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
