Popular and easy-to-use Audio Converter for Mac
  • 1
Popular and easy-to-use Mac Audio Converter
mac audio converterAre you looking for a solution or program to convert audio files on your Apple Mincintosh? Audio Converter for Mac can do this easily for you.
Mac Audio Converter is designed especially to convert audio files on mac os x. You can change any audio format between mp3, mka, wav, m4a, m4v, aac, ac3, aiff, amr, flac, wma, flac, ogg, cda, ra, ram with Apple Mac system.
With Audio Converter for Mac you can also extract audio from video files such as AVI, MPEG, WMV, MP4, FLV, MKV, H.264/MPEG-4, DivX, XviD, MOV, M4V, VOB, ASF, 3GP, 3G2, SWF, H.261, H.264, DAT, etc.
You can edit audio file with this powerful audio converter for mac tool, to split audio files, to trim music and cut songs as you want.
Mac MOV to MP3 Converter,
Mac FLV to MP3 Converter,
Screenshot of Audio Converter for Mac:
Main Features about Mac Audio Converter:
1. Convert audio files between almost all audio formats
Audio Converter for Mac OS X supports all popular audio formats, including MP3, WMA, AAC, WAV, CDA, OGG, FLAC, APE, CUE, M4A, RA, RAM, AC3, MP2, AIFF, AU, MPA, SUN AU Format etc.
2. Convert audio files from all video formats
Mac Audio Converter can convert video files to audio, such as convert avi to mp3 on mac, convert flv to mp3 on mac.
3. Customize output settings
Advanced encoding settings are all adjustable, you can set bitrate, sample rate and other parameters to customize output quality.
4. Edit various audio files
With Mac Audio Converter, you can cut the source file to remove unwanted part, and get a clip to convert. You can also join several audio files and output one file. Applying effects to audio files is also powerful.
5. Preview before conversion
Pre-listen the source file or the split part to ensure that you get the exact part as you want.
6. Batch conversion
Add multiple files into the file list, then you can have a cup of coffee or take a nap, it will finish the conversion automatically.
7. Easy to use
With its intuitive interface, you can freely and easily finish your conversion tasks with just a few clicks.
MP3 Converter for Mac OS X,
WMA Converter for Mac OS X,
Audio Converter for Mac will convert any audio files on your mac to your desired formats easily but with high quality and fast speed. Free Download Audio Converter for Mac program to have a try.
WAV Converter for Mac OS X,
A Link would be very helpful. Id be interested in taking a look at some gear
202
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
328
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
vivian20091010
bj
vivian20091010
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
