Porsche 996 Aftermarket Audio
  • 2
Eggbanjo
CarAudio.com Newbie
London
Hi all,
I am looking at replacing the old Porsche double-din head unit in my 2001 996 turbo with an aftermarket single-din head unit which gives Bluetooth convenience. There are 6 oem speakers in the car, and a Harman 49134 amp.
The head unit I have in mind is a 4-channel Continental unit TR7412UB-OR, which looks oem and presumably has a built in amp. Its max output is 41w. I think the speakers in the car are higher rated.
The question I have is (apologies it’s a bit noddy, but I am a novice here), can I connect the head unit successfully to the amp with an adapter (CT53-PO01), and even though the HU is 4 channel, will the amp still power the 6 speakers?
Thanks for any advice here.
If the company made the adapter for your specific model, they would have taken into account the OEM amplifier and put in a sort of line output converter to level the signal. The radio's amp will not power the speakers, it will still be the OEM amp handling that task. So no worries, all six speakers will still be powered.
Hi I have a 2006 Porsche 911 with the original PCM head unit/system. The prior owner had a Mobridge ABT2010 unit installed - it uses a Y cable...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
636
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
972
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
720
Eggbanjo
CarAudio.com Newbie
Eggbanjo
London
1aespinoza
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
