Problems after name change
I changed my name and now when i try to view my profile, check my inbox or look at likes i've received it sends me to http://www.caraudio.com/forums/members/big30016.html
can you either delete him since he hasnt been on since 03, or change my name back? thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The only thing I know for you to do is to change your username. Just let me know what you want it changed to. Sorry, just a bug in the software.
Yes I'm sure that's what happened. He was locked up at 16 and is still serving time but in his free time he dreams of coming home to browse ca.com
I was being serious with my suggestion. You could even make it 2 years of inactivity and that would still take out a good chunk of those dead accounts...
Just the first part of this made me roffle hard
me thinks it has something to do with the URL not being properly encoded when you click on a link.
nonetheless if you could change it back to "Kangaroux" that would be awesome. i had actually tried changing it back to that a couple days ago, but it said that username was already taken, so it's like it kept my old username somewhere even though I had changed it already. if you can't change it to that, "double deez" is fine
I got it changed over. Yea, its the SEO software screwing up the urls when certain characters are inserted as I suspected.
as long as you know whats causing it..thanks for the name change btw
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
937
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
868
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
Kangaroux
I put on
Kangaroux
Maine
Kangaroux
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
