Problems posting pictures
  • 2
qwertvt
Wharf Rat
24
Tampa
Whenever I try to hotlink my photos from imageshack, I get a message saying that the remote file is too large. I have looked around at other threads and it seems that others are posting pics that are the same (if not larger) in size.
The specs on one photo are -
Dimensions - 750 x 563
Depth - 24 bts per pixel
File Size - 213 KB
What am I missing? How do I post moderately sized photos?
- Thanks
I used that program to reduce the quality of the jpg image but the forum still tells me that the remote file is too large when hotlinking from imageshack. The pic is
Dimensions 800 x 600
Depth 24 bits per pixel
File Size 32 KB
http://img361.imageshack.us/img361/1268/1500000fm5.jpg
I can attach it; however, but I think doing this really limits the size of the photo.
Thanks for the help though.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
929
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
867
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
qwertvt
Wharf Rat
qwertvt
Tampa
qwertvt
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
