Problems with Car stereo
  • 2
Grimey
Aight.. I really didnt see another place to put this so.. I'm posting it here since this is about repairs and stuff.
Well.. the other day.. I was driving in my 98 V6 Mustang and I went over a speed bump real slow and the bottom of my car hit the bump. All was functional. I turned off the car to see if I had damaged my exhaust pipe cause it had previously been loosened (I fixed that). All was fine, but when i turned on my car.. my stereo wouldn't turn on. I got home and checked the radio... Wiring was connected correctly. ALL Fuses were all good (Tested em with a fuse tester). Fuses included the Radio fuse.. the fuses under my steering wheel and the fuses under the hood and all was functional. I Redid all the wiring and noticed that my amp didn't turn on either. So, I thought I may of blew the stereo itself.. I got my factory stereo that worked perfectly fine before and hooked it up and to my surprise, it wouldn't turn on either. When I turned on my headlights the lights on my factory stereo turned on but no buttons worked or anything. I hooked up my other stereo again and noticed it made a sound (like it was turning on) when I plugged in the harness. Still didn't work. Then I reset it.. Still nothing. I came to the conclusion that there must be a short or something in the wiring (not including the harness adapter i bought along with my aftermarket stereo) I believe I'd need a test light and check the wiring and replace the shorted wires.. I would really appreciate the help. Sorry for the little essay lol.
I have a Sony Explod Stereo with the face.
I have 2, 14 inch Pioneer Subs Hooked up to a Atx Amp (I believe its that one).. and ALL was working for about 6 months.
hmm. well if everything else is functioning, it has to be the headunit. maybe when you hit a bump, it messed something internally. if all the wires are correctly intact.
have you "shaken" the headunit and hear anything rattling around?
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
763
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
814
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
Grimey
Grimey
Kissimmee, Florida
Dirtrider4eva
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
