Pros and cons of bridging components
  • 4
ak47clown
Just curious about the benefits of bridging my system. I've got a set of rainbow slc components running off a diamond d3-400.4 amp right now. So according to diamond's manual i've got just shy of 60 watts rms running to them.
Forgive my ignorance but what exactly will I gain by bridging the amp? Obviously more power to the speakers-which from what i've read they can handle. But acoustically, what will I gain? Also, how noticeable would going from stereo to mono output on these speakers?
You won't go to mono on them if you wire them right. The front channels will be hooked to one side, both for input and output and the rear to the other. Still full stereo sound and the increase in power will add a lot to the dynamic capability of the system.
^ with what the poster said
you have a 4 channel amp. You only need 2 channels. By bridging it you turn 4 channels into 2 channels. So you're still getting stereo sound. The benefit is better acoustic range. Better tone quality. Smoothness of sound. Loudness.
you can also Bi amp them (using the rear channels for the woofers and the front channels for the tweeters) that way you have more adjustment with tweeters/mids
I agree with the brightness thing. I have mine set to black out in 5 seconds, lol. Never noticed the crossover issue since my dsp handles...
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
984
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
ak47clown
ak47clown
dirty jersey
ak47clown
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
