PRV AUDIO Audio 12MR2000-NDY and PRV Audio TW700Ti Titanium 4"
  • 3
Rrosario
CarAudio.com Newbie
12
Home
I’m stuck I wanna know what yah think .. excuse my spelling ..so my set up is what I have listed above 2 (12s ndy ) and three tweeters in a Brazilian box. I got the PRV Audio SQ9000X 1 Ohm . Which I was told is over kill for just two speakers so I have the choice now of making another Chuchero box with the same set up or buying 4 horns and making a driver box . For a loud clean set up would you just stick to another set up like I have now 2 12s ndy or get the “Drivers” . And if you say drivers which ones . As you know if I get the drivers ima need another amp I was told help me out I have for bass 2 kicker l7 12s.... and I gonna drown out the bass also would be another question of mine
Okay. So you have 2 12" MR2000s 8 ohms and 3 tweeters.
Your 3 tweeters are wired to a separate amp?
You are asking if the 9k will be too much for just two 12s?
Not really. Since you will be wired to 4 ohms. That amp will put out around 2.5k at 4 ohms.
I haven’t wired anything just because I’m trying to figure out can I run the speakers with the tweeters or do I have to do them apart like you stated is there a telegram chat group yah have or no or discord is dead lol
at 2 ohms it’s saying 6000 watts rms the amp I got is the new sq9000
Basically would you add another Chuchero box same set up or a 4 driver box what would sound the hardest
Was thinking of doing something like this before. If I Went with some **** like this I’d have a box for each 12 with 2 tweeters in them and just a Taramps 2K.4 for the Mids and a 1200.4 for the tweeters...i wanna hear and see that when it gets installed
This my set up
And that’s the amp
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
204
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Rrosario
CarAudio.com Newbie
Rrosario
Home
Rrosario
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
