pyle pa tweets same as sq?
pyle's pro **** is decent
Im running 6.25 mids in my doors
this. I bought a set of 8's to replace the very expensive 8's in my kickpanels before I sold the car.. WOW, was I suprised what $30 bought me. Midrange wasn't as clear, but my midbass improved and output was the same or a bit better (granted the pyles were getting over 2x the power since they were 3ohm drivers). I had 300 watts a channel and they def didn't "like" it persay at full volume, but they took it pretty damned well, I was very impressed..
Odds are the tweeters are about the same or very close. If your looking at adding multiple set of tweets your not looking primarily for quality anyways, you want cheap and loud, get whatever is cheaper, I've heard the AQ tweets. Properly setup they don't sound bad and I've heard enough pyle pro to assume they are the same way.
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
752
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
6
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
7
slvrado28z
slvrado28z
midland, tx
T3mpest
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
