Quality 2000W Amplifier
i had the old cadence z7000 ultra drive pushing my 2 12" type R's and i couldnt give them all the power of the amp @ 1500watts. 2000 watts for the type R is to much. i would shoot for a good 1000w or 1500W look at sundown audio, SAE-1500D - Sundown Audio Monoblock 1500W RMS Digital Class D Amplifier 400$ gonna be well worth it !!
I think you linked the wrong one
Ive got the american bass vfl 4480. Its rated at 2200rms but its probably somewhere 1500- 1800. Its stupid efficient. At full tilt on my hardest songs it would only drop .6 volts off my 200 amp alt without the big three. Ive clamped it around 800 watts at 2 ohm. Its only like 270 shipped. Its a pretty good choice for the price
Ct 1400.1 was great for me before I moved up to a bigger model. I only had a 140 amp alternator on my 4Runner but I did a big three and a dual battery setup. Factoring that you may be running a 4channel amp for your other speakers you may want to think total draw on your electrical, not just one amp. the ab vfl 4480.1 looks like a solid amp and great buy as well.
I would recommend a VFL 100.1 or 120.1, not the hybrid but the full size VFL amps. The vfl100.1 I had clamped over 2800w@0.5ohm, and it didn't even get warm. I've run everything from the a pair of 80.1's strapped up to the 500.1 and never had an issue. I bought all mine used, so there's no telling what some other idiot has put them through.
Sent from my SM-G925T using Tapatalk
I was looking into the Rockford Fosgate R1200-1D amp for the 1200-1300W range.
All of my door speakers are powered from the head unit, so minimal power draw there.
I do need to do the BIG 3 upgrade, as well as getting a second battery. What do you all know about Hifonics amps?
I second this. EVERYONE on facebook, even seasoned vets ran and hated the vfl hybrids. I'd run audio pipe apcls before even looking at vfl hybrid amps.
On a side note I have the American bass 3k power that's rated 250a fuseing and full range capable as well as low pass. I have it at 1ohm and it doesn't even get warm. It's a solid amp.
16
NVX X Series and V series are pretty darn good for the money all the way around.
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
Zeditious
Zeditious
TN
jordon
