Quality wise
if buying new the kicker is cheaper but its 2 ohm stable where the rockford is 1 and will do 2500 @ 1 or 2 ohm. if u can find a older model like the 2003-2006 they will give 2500 @1 ohm and on good electrical can run down to .5
Fosgate amps aren't affected nearly as much by impedance rise during music. They will continue to put out rated the entire time. The ZX is no slouch, but it is far removed from the KX or older Kicker amps. Like stated earlier, the ZX will be easier on your wallet than a RF Power amp. It might be worth the money though.
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
NVX X Series and V series are pretty darn good for the money all the way around.
6
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
cleansoundzz
cleansoundzz
Buena Park
MrMike
