If Voltage of the output = sqrt(RMS Power X impedance of the speaker)
I have a Kicker 12" 800 Watt 4 Ohm Dual Voice Coil Comp VR. I have it bridged down to 2 ohms.
But if I want to determine the needed output voltage from the amp, would I use the 4ohms that the sub is rated for (which would make the needed voltage 40 V) or do I use the 2ohms that I have it set it up at (which would make the needed voltage ~28 V)
Thanks
Thanks
