Question on Amp/Deck Setup
  • 2
jgruberman
I just received my wonderfully German Engineered DSC4125 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm reading the manual on the can and I see here it says "It is important to match the amplifier LEVEL input sensitivity to the Radio/CD output sensitivity. This can be located in the Radio/CD manual. If the Radio/CD output sensitivity is 2 volts, then adjust the amplifier LEVEL input to 2 volts."
Now I understand all that and what it means, but I can't find for the life of me the output sensitivity on my deck in the manual.
The manual is here: http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/49731CRD3301A_200012301325447930.pdf
Maybe there is a different terminology that Pioneer uses for output sensitivity? Ay help here would be great... so far the amp sounds awesome, want it to sound perfect!
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
757
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
jgruberman
jgruberman
North Dallas, TX
pheonix991
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
