I had a 2005 Toyota Corolla with a stock head unit. When removing it, I disconnected the negative battery terminal and unhooked the wiring harness/antenna. However, the next morning I noticed the car was shaking and hesitating when idling. The next day I installed the after market head unit (using the Scoshe wire harness), once again, disconnecting the negative battery terminal. The radio worked fine. The next day the car quit on me in the school parking lot. It would just start up and stall out after a couple seconds. My dad and the tow truck guy both thought the fuel pump had failed. We brought it to an auto shop. They put in a new pump and the car still didn't start. The mechanic then diagnosed it with an ECU/ECM (however you want to abbreviate it - the car's computer) as the problem.
Good thing that Toyota has the 8yr/80k warranty on the ECM. I am going to get it towed tomorrow to toyota and they will take care of it.
The Corollas (especially around 2002's) have an infamous history for ECM problems. However I'm 99% sure this was a result of my radio upgrade. I read this where it was explaining how to get a stuck disc out of the stock player but it had some interesting information:
"The other method is to disconnect the power to the head unit for a few minutes and then power it back on. It should spit the CD out. Drawbacks of thismethod are dependent on what equipment you have on the circuit at the time and how you pull the power. Disconnecting the battery is the easiest method - but you will lose time, possibly lose ECM parameters (will run a bit odd until it "relearns"), if equipped with an alarm system (headunit, kill switch, pass keys, etc. - may do all kinds of weird things). To avoid those issues - just pull the fuse leading to the radio (should be listing in the operating manual). My fuse was located by the driver's side kick panel and was marked RADIO."
Toyoland - Toyota Corolla common repairs
Were the repeated battery disconnect the cause of a faulty ECM? I still have work to do on the car and I don't want this happening again once it's fixed. Would the fuse removal solve this? I've never read anything about this in any guide/tutorial. Please Help.
Thanks,
Nick
Thanks,
Nick
