Radioshack out of business! Picked up a ton of stuff
DarkKnightSM
So it turns out radio shack is going out of business and some of the locations are being bought by sprint or whatever. Everything is 50-70% and some stuff like small electronic parts are even more. For instance i picked up a ton of switches, relays, resisters, for a buck! Normally there 5-6 bucks each. On top of that picked up a heat gun, solder iron, wire loom, wire that lights up! Now i just need to figure out how to wire in lights that turn on when the car turns on
I just wired some leds off my aux power 1 works great, just tapped in to power and ran another ground pretty easy stuff if this helps any
I wanna wire in a ton of leds, so some wiring is in order. Where should i pull power from? I can pull it from my distro block? Then run all thegrounds from the leds and switches to the ground on the distro
There was one by me but it's independently owned. Big sign that says its staying in business.
***** because I would of cleaned them out.
I spent like 250 bucks on stuff. At a parts store would have spent close to a 1000
Dang lucky you.
I really wanted to show off my slickkkkkkkkkkk wiring skillz.
Oh well, I'm sure it will go out of business in no time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dang lucky you.
Read online! I thought they were going out of business nation wide
DarkKnightSM
DarkKnightSM
Co Springs
Louisiana_CRX
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
