Random Sub Questions Thread
  • 3
I see some subs have an option for “standard” or “ohm true.” Can someone explain what ohm true is and how it’s different from standard?
32011
I'd guess "standard" 1 ohm coil for example may have DCR of .7 or .8 while true would be 1.0. Your amp should "see" whatever true number is published. It is highly likely if you need to worry about this to optimize some sort of top tier SPL build just ordering blind won't help anyway as your actual impedance in your box in your car will be a complete unknown until the sub(s) are installed and tested.
Long story short, I'd buy "standard".
Hi all, Wondering if anyone has any experience with the Nakamichi NAM351-M7 head unit? Mainly with the random play setting with MP3s on MicroSD...
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
285
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
464
Marve_Lous
That Guy
Marve_Lous
Houston, TX
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
