Rattle
  • 2
When I put sub in enclosure it rattles from the cone . If I pull the speaker out it doesn't rattle . Sealed enclosure 1.5 cu ft JL w1 v2-4 . Alpine mini 500 . Push test is good . Ohm test is good .
II think your dust cap has a small unglued section. When in box, air escapes via unglued section causing the rattle. I have dealt with this same issue. Tape the perimiter of the dustcap and play at different volumes.
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Example. H.depot or Lowes should have some also? or a hardware store
9
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
Play the system when your muffler is cold and crawl under there and grab shitt until it quits rattling. That is really the only way to fix the...
10
Mofongo13
CarAudio.com Newbie
Mofongo13
Fort worth. Texas
1aespinoza
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
