Re Audio amp XTX 5000
  • 2
rlambert02
PHX, AZ
Does any one know anything about this amp or RE amps in general. I know they make good subs but I dont know about their amps. this amp is rated at rated @ 2500 rms.
So does anyone know anything about whether this is a good amp or not?
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
rlambert02
rlambert02
PHX, AZ
needthat22
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
