RE SE or Kicker CVX?
if you ordered 4 of them, then I hope you have at least 3600-4800 watts on tap. I have owned one and they do get loud but they don't even play to their potential until you feed them about 1200 watts a piece.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
911
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
SilverSquared
Fat guy on the GROUND.
SilverSquared
Southeast Louisiana
Lakota
