really need help, I truly value you guys' advice
  • 3
bluemarvin3030
Need help with lpf settings. H/u is pioneer avh x5600 bhs, amp is alpine mrv-m500.
Unfortunately I don't know as much about car audio as I would like to believe. Lpf settings available on both h/u and amp. Cannot turn "off" either one. What to do in this situation. I have read not to use both, but no explanation on how to disable one or the other.
Please help me, you f*@king geniuses.
I would think you could turn it off on your hu but just set the lpf on both the same or just set the one on you hu as high as it will go and then set the one on the amp to you liking. I usually set mine around 80hz
OK that's what I came up with, except I only set h/u to 100 hz, just so they weren't the same. I will change it higher. My amp is set to 80hz. But yeah this h/u won't turn off lpf, weird huh. Thanks for the input.
Thanks a lot. iPhone charging. Wow. No cigarette lighters now.
35
6K
If you have that much then yeah go for it. It's incredibly nice to just have the option. I remember the first time driving after I put it on...
16
3K
Historically better economy under Democrats.... ********. CPI:
176
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
bluemarvin3030
bluemarvin3030
Oakland, TN
bluemarvin3030
Dylan27
    Jun 4, 2024
winkychevelle
    Jun 3, 2024
