Redoing my wiring
  • 3
cbuts
Hey im going to be redoing my wiring and doing 2 runs 1/0 to back amp rack distribution block and aldo putting in h/0 alt.
Two batteries under hood.
Can I run EVERYTHING off the second battery? Both 1/0 runs, all my alt and extra grounds ?
Or is it better to split it up?
Thanks
It does not matter just as long as the other battery is in circuit. I would run a ground and power(obviously) connecting the batteries.
Thank you, yes ofcourse I'm going to run power and ground from each, plus a ground from each to the frame..
Just wasn't sure if it was a better to run half to one battery and half to the other lol.
I'm just just run everything off my 2nd battery, big 3, extra grounds, and my 2 runs of 1/0 to back amp rack.
Thank you
Just curious, why 2 runs to the rear? I had thought 1 run of 1/0 ofc will handle up to 350amps? And for what it’s worth, my alternator is wired to my battery of course, but my run of 1/0 runs to the rear, right off the alternator. Connected to my lithium, then I have 2 runs from it to my md5000.1
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
108
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
518
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
560
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
599
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
517
cbuts
cbuts
canada,ont
JakeW
winkychevelle
    Jun 3, 2024
