Remote Wire to Fuse Box Help
  • 2
I have a 2012 Buick LaCrosse that I installed an aftermarket amp and kept the factory HU. I ran my remote wire to the fuse box under the steering wheel, and connected it to the radio fuse. Everything works fine except that the amp stays on even when the car is cut off and the keys are out. I’ve tried every other fuse on that fuse box, and the amp stays on no matter what. Any other options y’all might know about?
yeah, it'll be hot but off. Just like your tv when it's plugged in.
Remote turn on. Going to check it later this week. Almost 100% certain it's something with the amp. I am assuming that a resistor inside went bad...
9
With the amplifier fused it will be fine for testing an amplifier to see if there is an issue with the remote wiring coming from the HU, or great...
4
As stated..A jumper wire from remote to Power on amplifier will be a nice little test to see if the amplifier is working. If it does, I would...
Marve_Lous
That Guy
Marve_Lous
Houston, TX
Ripkon
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
