Removing old reciever speaker connections
  • 3
ElectricSoap
So I have an aftermarket sony reciever with RCA plug ins. I have had the speakers connections crimped to the the wires that plugin to the reciever. Now I just got a new amp and will be using the RCA cables, I wanted to know if I could leave the speaker connected since I still need the power cable and such from that plugin for the reciever or if I have to uncrimp the sony wires from the factory speaker wires. I will be running new speaker wire from the amp. Will the old connections interfere even if they aren't hooked up to anything?
cut em and cap em (or tape em individually). they will short out on stuff if you dont
Unplug the current wires from the speakers and tape them to keep them from shorting out. Leave them so that if you ever decide to remove the amp you can just untape and reconnect the old wires.
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
8
ElectricSoap
ElectricSoap
Odenton, MD
Slo_Ride
Latest topics
