Resin inside of box?
what is the purpose other than wasting time and $$$$.....
Caulk to seal the joints if your cuts are off......wax if you want a slippery surface. If you need strength then add bracing as resin does nothing to make a box stronger unless you use fiberglass mat and that won't be fun....
Resining the inside of the box seems like a lot of work for no real gain. I can add silicone caulk to the corners like dude mentioned above^. If your looking for smooth air flow, maybe a layer of paint to help make the internal surface be smoother. If your looking at adding strength, try extra bracing
it lowers the resonance, strengthens it and seales it. wood is pourious reguardless.. ive put up better numbers by just doing two coats of resin
you talking to a guy that has built more 156 db+ cars than you ever will in your lifetime lol.
i dont care, ive built plenty on system and it has made a difference. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
---------- Post added at 09:53 AM ---------- Previous post was at 09:53 AM ----------
What did U gain .01db..... Resin isn't worth it.
.2 hehe
corners and airflow are important. i gained by sealing the box and reducing resistance inside the bbo buy rouning the corners.
153 with 1 9515d and about 1.5k was a **** good score..
anyone tested it?
unless it is an all out spl big build not really worth the time or money. Same with 45s. You can gain or drop on the meter because of them.
the less resistance the more linear the pressure in a system. we can argue all day. one thing i do for a living is pneumatics.
Just when you think you're humming along... and... hmmmm happens!
22
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
disturbed471985
disturbed471985
Greenwood, La
Papermaker85
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
