rockford hx2's
  • Thread starter <kithut84>
  • Start date
  • Replies 2
  • Views 2K
  • 1
<kithut84>
Guest
I am looking at getting 2 15 inch rockford HX2's,not the power just the normal punch. i am going to get a mtx 81000d amp, it is 1500 watts. do you have any other suggestions for the subs? how do the hx2s sound? i can find them for 150 a piece. thanx
im sure the hx2's are pretty loud.. not good on the sq side but when you into spl who cares right
. im running the he2's in a sealed box off a dei1100d and im doing 147's.. pretty good for the he2's i think. anyway i think they are a good quality sub.. just my opinion tho
It sounds like that would be a good setup. 1 question, how much is the amp. I went to my local car audio store the other day and was told that you should spend at least $1,000 to $2,000 on the amps. The hx2's are very powerfull but you need to run a lot of power to them and you also need a very big box in order to get the sound you are looking for. hope this helps
940
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Guest
