Rockford T2500
  • 4
the low pass crossover set at 80 hertz will allow your sub to reproduce frequencies 80 hertz and less and will reduce output on frequencies 81 hertz and higher
I like to set mine at about 80 too... most subs don't play really well above about 100hz anyway so setting it higher than that really doesn't benifet much of anything
why don't you tell us what all the settings on your sub amp are set at 1st
and also what settings on your head unit are set at 2nd
then we may be able to help you better
the low pass crossover set at 80 hertz will allow your sub to reproduce frequencies 80 hertz and less and will filter out frequencies 81 hertz and higher
I could be wrong, but I believe its sloped...So 81 would not actually cut off, thats where the slope would begin
my hu is pioneer 3200... subwoofer set at 80hz, normal not reverse, at about -8 my amp gain is about 4/10 of the way up.. phase 0..running at 2ohm with four 4ohm subs
11
954
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
9
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
11
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Rocky213
Rocky213
South FL
Rocky213
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
