Rockford t400-4 brigged and stable at 2 ohm?
  • 2
Kross6622
SCS, MI
Well today i was just messing around looking up some manuals of amps i have and i looked up my rockford t400-4 amp and noticed something in the manual. Now i have the 07 version which is rated 60@4ohms x 4; 100@2ohms x 4; 200@4ohms x 2 and then it says; 2ohm Load Bridged STABLE
So my question is, even though it doesn't rate a power at this Impedance it will still run at that low of ohms? or is this a typo?
Heres a link to get the manual, http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/fattach_get.php?p_sid=l_NXyj*j&p_tbl=9&p_id=817&p_created=1171995579
Now im currently running it bridged at 4 ohms, and its rated 200w but the birthsheet says 250.
So my next question is, if it is stable bridged at 2 ohms, why didn't they put a power rating, if i did run it what would i expect in terms of power.
anyone ever clamp test this amp? i know its a multichannel and i dont see many clamped tests done for them.
11
966
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
9
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
11
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Kross6622
Kross6622
SCS, MI
Kross6622
