Round port help
  • 2
Banzai250
CarAudio.com Newbie
Hello everyone! Newbie here with a dumb question please! I’m currently running a 3 inch round port on same side of my American bass xd12 woofers ( two woofers with wall between, 2.15 cu ft each ) I like to run 4 inch port but I don’t have enough space to fit the woofer and the port together ! My questions is can I run 4 inch inside the box and connect with a 3-4 inch reducer ? Would it make any difference ? Btw right now the box are tune to 30 hertz , Thanks in advance 👍
Keep the same size port. Using reducers will **** with tuning and cause compression on the port which will hurt output.
3 inch ports are undersized for those woofers. You need to be using 4s or a single 6. You can buy pvc elbows at hardware stores to bend the port tubes to achieve your desired length.
Thanks for the reply ! I don’t think I can fit 4 inch port to the same direction as the woofer , let me ask you this , are 2.0 cuft enough for the AB XD12 ? I also pick up a set of Audio pipe Txx-Bd2-12 . Will it work in the same box or I need to build a bigger one ? Thanks
What’s up y’all, new to this place… today actually… Idk, i guess if I’m gunna ask for help wit this mess, now is prob the time…. First things...
Once you get the tools and basics down it's not too bad. The turn table is a must imo.
https://audioassemble.com/round-vs-oval-speakers/#:~:text=If%20you%20opt%20for%20a,it%20is%20small%20in%20size. This is what I found with a...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
Banzai250
CarAudio.com Newbie
Banzai250
Austin.Tx
THATpurpleKUSH
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
