rumble sound from subs when i turn on/off cd player and when i turn bass knob up
  • 2
Haystak
ill start with saying i have a sundown audio saz-2500, two DD 2512s ported bbox, optima yellow top, 0 gauge streetwire wiring kit.
ground is connected to a seatbelt bolt in back seat.
from subs to amp i using 8gauge..theres terminals on my amp so i basically have both wired seperatly at 2 ohm each...(pos to pos to pos neg to neg to neg) so if im right that equals 1ohm load
problem: when i turn the bass knob up i head a rumbling sound (only first few notches on knob though) and when i turn the cd player on (when amp turns on) you hear kind of a pop sound
i understand...but it has two sets of terminals that are internally connected.....so if i do Option 1 (parallel) = 2 ohm load Voice coils wired in parallel
so if i do that to both and have each connected to their own terminal that would make 1ohm...right? or do i have to wire the subs together? and i dont have a DMM :/
I have my big 3 done in 1/0 so I got those grounds done up front. Both amps have their grounds to the reserve batteries on buss bars. Sub amp has...
6
Hey all. Just took my car audio batteries out to build a box for them. When I hooked everything back up and turn it on. My subs have a constant...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
897
Haystak
Haystak
Gatlinburg Tennessee
Haystak
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
