Running 1.5ohms on a 2ohm stable amp?
  • 3
after rise you should be fine! probably a bit over 2 ohms!
x2. The amp should be fine. If it has built-in protection circuitry, it should cut off when it get's too hot. If it doesn't have built-in protection, just keep an eye on the temp.
Cause i've noticed on certain songs, on a part where it should be constant bass, the bass level goes up n down. And it's somewhat noticeable. maybe it's my weak electrical then? (aka stock)
your stock electrical shouldnt drop like that on 500 watts. do the big 3 atleast and start from there.. make sure you have real good ground and that everything is tight. play the music with the constant bass and put a dmm on your battery and see what type of voltage its operating on..
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
668
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
thisistiny
Graphic Designer
thisistiny
Las Vegas, NV
BloodyGuts335i
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
