Running a DSP With an 80prs?
  • 3
SeniorXJ
I'm thinking about adding a third amp to power more speakers but the Pioneer 80prs only has three lines out and I would need a fourth. Would running a DSP with the Pioneer 80prs be a good idea to get a four-way active system?
I have two 8" Beymas and two 3" peerless tweets in the doors and want to add in a set of 6.5"s in the kicks.
Thanks 👍
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
667
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
SeniorXJ
SeniorXJ
Albany, NY
Boominburban
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
