S.0.s need help on which sub/amp to get from amazon!!!!!!
Ali2627
HIIII im brand new here and i need help of pros i have no idea about subs but i have 3 picks after doing research of subs around 100-130$ price point. I have a honda insight aka a pruis if you have no idea what it is so either i can have a low profile sub under my seat or have a small sub box in the hatch ( aka the trunk but its open to the cabin )
Please tell me which would best View attachment 26557425View attachment 26557426View attachment 26557427
>Sound storm
>Kenwood
>Rockville
https://www.amazon.com/Rockville-RWS12CA-Powered-Subwoofer-Enclosure/dp/B01DNT4YBA/ref=sr_1_23?ie=UTF8&qid=1525203230&sr=8-23&keywords=subwoofer+and+amplifier
https://www.amazon.com/Kenwood-KSC-SW11-Compact-Enclosed-Subwoofer/dp/B00BO8O9XQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1525203743&sr=1-1&keywords=kenwood+sub
https://www.amazon.com/dp/B0082YUR7M/ref=sspa_dk_detail_1?psc=1
just looking for good base nothing to break the windows if you know what i mean also my car is weak on power so keeping the watts low is ideal only got 89 horsepower hah
>Sound storm
>Kenwood
>Rockville
we aren't big fans of powered subs, they're all pretty weak.. u can't do a $70 sub $70 box and $120 amp with $40 wire kit? if not get a rockville (maybe not that one they have others) but buy it on their site and u should have 90 day return option if u hate it.. here's the other one we don't know which is better because none of us have these https://www.ebay.com/itm/Rockville-RVB12-1A-12-Inch-500W-Active-Powered-Car-Subwoofer-Sub-Enclosure-Box/390836979253?hash=item5affb30635:g:yAcAAOSwDshZvW-3#rwid
Friend of mine put one of those under-seat powered woofers in his WRX. You can't hear it. Not worth the money, IMO.
If you can afford it, it's better to put one together yourself. Woofer, box, amp, wires like Gramps said.
I see thanks for the comments ! I’ve seen that other rockerfillve but I thought it was ugly , hah. But anywho my price range is 50$ max I wana spend cause I have to pay to have it installed since my car literally is a pain to work on si car there is little support for it. I wana buy from amazon cause they have a deal for 90$ for a installer to hook it up and if you don’t like it you get ur money back.
I’m just looking for a nice crispy bass boost to car not heavy and I have limited power so keeping the watts low //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What about this ? I think this sub with an amp should be good ? Pioneer
Pioneer TS-SWX2002 8" Shallow-Mount Pre-Loaded Enclosure https://www.amazon.com/dp/B01FR5HDZ2/ref=cm_sw_r_cp_api_i_eDB6AbB8YFTB7
With a 1100 watt bosss amp ?
Would this be better ? ^^^^ it totals to 150$ Amp/sub/wire kit
*******update reviews don’t look good have to keep it face down and it will take space can’t put stuff on top. Also 1110 Watts is too much ? ? Said online that 500w is all it needs or less
>Sound storm
>Kenwood
>Rockville
Rockville and Sound Storm are bottom of the barrel flea market junk. Avoid at all costs. Kenwood isn't really a great name in subwoofers or amps but they should give you reliability and perform as advertised. I much prefer JBL/Infinity for amps and loudspeakers as far as mainstream brands, they used to make a few powered subwoofers and may still, not sure if there's anything in your budget though.
I will also suggest that buying separate components and doing it yourself will give better results but I understand that for simplicity buying an all in one unit and if you have reasonable expectations you should be happy enough.
I see I felt the same too but what would you get with 150$ sub and amp ? There are a few good onces I’ve seen maybe you can give your opinion on the pioneer sub in my comment above yours ^ seems like a okay brand ? If you have the time maybe snoop on amazon and see if anything pokes out good to you. Has to be amazon though cause I’m having it installed through them with a 100% money back garingue which I want
save up your money and dont waste it on garbage that you'll just upgrade later on. Wait till your budget grows to a healthy amount. If you spend it on garbage left and right you'll end up spending a lot more overall than a quality setup from the start.
There's a couple Pioneer amps out now that are super cheap at WalMart that apparently perform quite well. I can't vouch for their subs because I've never used or seen any in action.
Thanks for the input everyone but I gotta remind y’all I’m not going all out with high amp large subs my car can’t supoort it. And I do know 150$ isn’t much but it’s what I got and I’m sure there is decent subs/Amps for someone who just wants nice clean bass to enrich the song I don’t like large subs cause it’s too over powering and will be more bass than music since I only have 4 speakers and they are 3x4
My current eye is either on that rockerfiler when though it’s said to be trash but the views are better than everything else for 150$ or a Pioneer 8 or 10 inch sub and a 1100 amp for 159$ I’m really just looking for what’s less shitting than the other haha !!
>Sound storm
>Kenwood
>Rockville
https://www.amazon.com/dp/B0082YUR7M/?tag=caraudiocom-20
I have read the best reviews from the Rockville rws12ca. About 90% positive. The negative ones more than likely received some duds, which happens with even higher priced products. But the good thing on these is that if it turns out bad, and have a warranty for a replacement, you just unplug it on the side and plug in the new one. No need to rewire. Good luck.
hey dumbass this thread is 2 years old....quit trying to be a "hero", all the advice you have given so far is some the stupidest sh*t i have read
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
This thread is over a month old. Shame I missed it, the whole thing is shameful and hopefully OP made those people give him an install that...
6
Ali2627
Ali2627
Los Angeles,ca
YourNameHere
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
