SA-8 v.2 enclosure help.
  • 2
Nonten03
sapulpa
I'm new at this forum, but i been browsing around for a little awhile. I was thinking about pre ordering the New Sa-8 that are coming out, but I have a few questions. If anyone can help me out, it would be much appreciated //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What would be the BEST dims for a enclosure for 3 Sa-8's?
Should I get Duel 4 Ohm or Duel 2 Ohm?
Does sundown have decent SQ?
The dims of the enclosure would be based off what space you have available and what the overall desires response is wanted. The vehicle and power play a roll in the design as well. The coil setup would depend on the amp you plan to use.
SQ is subjective and in the substage it has more to do with the enclosure/install then anything
Thanks. The only problem is i'm getting a new car soon, so i won't know how much room i got lol. I kinda of wanted a idea how big the box is going to be.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
9
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
7
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Nonten03
Nonten03
sapulpa
Nonten03
winkychevelle
    Jun 3, 2024
