Scion Tc Backup Camera Wiring
  • 1
Selvos
14
Europa
Hi
I'm installing a backup cam for my Scion TC. The camera is mounted and I have the wiring through to the liftgate.
I need to get power to it and power to my wireless transmitter.
First I'm going to tap into one of the light's power, but i'm not sure what color is the power and which is ground. There's a black and white wire and a brown wire. I'm assuming brown is ground, but I saw a black/white wire attached to the liftgate chassis. SO now i'm not sure.
DOn't have a meter to check. I'd rather connect to the reverse light....Has anyone done this...where did you run your wiring?
ANyone do this to a TC?
What did you do?
I have a 2012 Toyota 86 (Australia), with the standard factory fitted head unit. It has served me well over the years. All of a sudden the...
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
It only works when the car is in reverse. Also, some units have trigger options in the settings menu.
591
How positive are you that the reverse camera power supply was spliced in with a reverse light wire? If you used one of those blue wire splicers...
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
9
Selvos
Selvos
Europa
Selvos
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
