Sealed enclosure size for 5 1/4 hertz hsk 130 speakers
If you give us the t/s for the drivers and the mathematical transfer function of your car we could let you know the optimal box size.
Expect to build at least 3-4 different enclosures to get that right.
D mm 105
Xmax mm 3
Re Ω 3,1
Fs Hz 80
Le mH@1kHz 0,34
Le mH@10kHz 0,19
Component 2 way system
Size HV 130 woofer 130 (5”1/4)
mm HT 25 tweeter 25 (1”)
Power W peak 200
Handling W continuous 100
Impedance Ω 4
Frequency Hz 60 ÷ 22k
response
Sensitivity dB/SPL 91
Crossover LO/HI-pass 3.2 kHz @
included 12/12 dB OCT.
Component Tweeter -2; 0; +2
adjustment
Outer Ø Woofer 131
mm Tweeter 44
Mounting Ø Woofer 115
mm Tweeter 41
Total depth Woofer 73,5
mm Tweeter 26
Mount. depth Woofer 65
mm Tweeter 15
Magnet size Woofer 85
mm Tweeter 24,5
Weight of one Woofer 1,04
component kg Tweeter 0,06
Voice coil Ø Woofer 25
Vas l 5,00
Mms g 9,5
Cms mm/N 0,45
BL T-m 5,40
Qts 0,50
Qes 0,55
Qms 11,00
Spl (1m/2,83V) dB 91
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and...
48
7K
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
752
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
fatboyracing
fatboyracing
Owensboro KY
fatboyracing
